The fuel pump should run for a few seconds when you turn the key on. If it does that and doesn't start then possibly a crank sensor. If the pump doesn't run then it's not a crank sensor.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
