Nice Mopar Prochargerman!
We need more 71 Plymouths doing the 1320 lol...
Hopefully my 71 GTX will be back out after 20+ years doh...
I've been doing some small block porting too for my 64 truck.
But if I was gonna have a trick 71 it would be a 400 stroker methinks?
There is lots of info on heads and the all say ''don't go bigger than 90%' in the throat''...
But if you do the proper throat cut with a decent 'cutter' the the throat angle is already done for you...75 degrees or even 70 is OK!
The exhaust has a wonderful shape in the bowl area, so 'easy peasy'...
