A gel coating, mine had a hose leak since new and under the hose on the block surface is a glazed somewhat clear coating that I could peel off. I’m guessing if there’s any sharp bends in the core it could slow the fluid down enough to form this layer then keep building up over time till clogged. I might replace with regular green AF, radiators are cheap today
