[quote][/quote]
I assume you have a tunnel ram with a dual Dominator pattern that you are trying to use? For a street car a pair of 4150 carbs would be better but you could make the 750 Dominators work if you want to go that way. Not a very friendly street setup but if you only drive it in the summer to cruise in events then you should be able to live with it.
Actually I was after the look of a dominator too. I don't have anything yet but I keep kicking the idea in my head. The car sees the track a few times a year also
