Certainly not this forum unless the engines have “let’s go Brandon” or BLM painted on them!
You probably want to go in this forum:
https://board.moparts.org/ubbthreads/ubbthreads.php/forums/13/1/moparts-engines.htmlFind the appropriate sub forum under that one. Like if it’s a big block, reply to the first post in that sub forum, or the last. Change the title to describe your engine. Then type your description and make sure to include a price and contact info or the mods will delete your post.
Some newbies have trouble posting pictures. Look toward the bottom of your post you are creating and you will see a paper clip and the words attachment manager, click on that and add your pics.
Good luck.
