I can see where more power and rpm require bigger clearances and heavier oil. Look at what the fuel motor guys use. I believe clearances are much bigger (.006 to . 007?) And oil is straight 70 weight?
The amount of flex etc is huge, so big clearances and thick oil let them live.
