If you is going stroker then a 511 kit is super cool!
That's the biggest you can go with a standard internal oil-pick-up system.
4.250 crank with 7.100 rods and custom pistons I suppose?
This is my mates 511ci 'daily driver' with a 950 HP Holley carb.
Does 15 to the gallon, with 600hp and 'goes off the clock' with ease... drive
Yep that's a dual-plane intake manifold with standard port heads... whistling
I know that Brandon at '440 SOURCE' does a 526ci kit for the 426 block, WOW!!! fan
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
