I think I know the answer by looking at the car but will a one piece trunk pan fit in place on a 68 Charger with only one quarter removed ? Or only through the back with valance or taillamp panel off? Thanks in advance all.
No, It will not go in from the side. The wheelhouse and trunk hinge support is in the way.
Here's a link to how I do it.
The Charger is one of the easier cars to do install the trunk floor from the rear. Only need to remove the rear valance. But bear in mind, the 68-70 Charger bodies are one of the most complex cars to restore. There's a lot going on back there
https://board.moparts.org/ubbthread...-floor-installation-yes-it-will-fit.html
