Originally Posted by Greenwood
Looks like I'd better do some more checking. I only snugged the bolts, then measured at a 45 deg. angle from perpendicular. Thanks guys!
That would certainly add to the inner diameter measurement. When you torque the rods clamp them across the parting line. A couple pieces of aluminum in a vice will work.
Doug
