Re: 276, 294, 323 rear gear
[Re: 360view]
#2979287
10/28/21 03:43 PM
10/28/21 03:43 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You guys can keep your tonnoue covers, I am constantly putting things in and out of the bed so that's a no go, I have had em on trucks I bought before and HATED them!
My truck has 3.55 gears, don't know why anyone assumed 3.23s? The tach is reading a little higher on the dash than it is with the scanner hooked up but still, just over 60 it hits 2000 rpm verified by GPS. Trans works great.
When I had a 318 4wd dakota I had zero issues running it down to 1000 RPM in 5th around town and got nearly the same MPG in town lugging it like that as I did on the highway where I could not lug it because it was turning too many RPM, that truck had 3.55 gears but taller tires, they were 17 R/T wheels but don't remember the exact size. It was a bigger heavier truck with much taller tires and I still found myself wanting a higher gear, maybe I should swap in a 6 speed Manual with a .50 OD ratio instead. Leaving the 3.55 in there would give me a 1.77 final drive ratio where the 2.76 a-500 only gives me 1.90 final drive. Some cars in the 80s had 2.20 ratios with less tq, 318 magnums easily have enough TQ to work that low and like I said I can easily add a few more foot pounds of torque. Now to find a 6 speed...
Entire Thread
Moparmaniacc
10/21/21 10:08 PM
HotRodDave
10/21/21 10:25 PM
1969ronnie
10/21/21 10:42 PM
1969ronnie
10/21/21 10:48 PM
Moparmaniacc
10/25/21 12:26 AM
1969ronnie
10/26/21 08:52 PM
MarkZ
10/21/21 11:29 PM
A727Tflite
10/22/21 01:09 AM
MarkZ
10/22/21 07:55 PM
A727Tflite
10/22/21 08:04 PM
TJP
10/23/21 12:46 AM
poorboy
10/23/21 01:32 AM
Sniper
10/22/21 08:13 PM
HotRodDave
10/22/21 08:23 PM
GMP440
10/22/21 03:30 AM
jcc
10/22/21 07:20 PM
6PakBee
10/27/21 01:49 PM
360view
10/22/21 09:13 PM
HotRodDave
10/22/21 09:35 PM
360view
10/23/21 10:49 AM
mgoblue9798
10/27/21 01:59 AM
360view
10/27/21 12:52 PM
HotRodDave
10/28/21 07:43 PM
360view
10/28/21 10:55 PM
Moparmaniacc
10/29/21 11:58 PM
