OK, here is a guess. Maybe the additional lift of the cams put too much stress on the needle bearings and caused them to wear instead of spin? That would go with your idea that larger needle bearing are stronger and have more surface area to spread the additional load.
There are some videos suggesting the stiffer valve springs in the 09 and above Eagle Heads contributed.
