Originally Posted by PhillyRag
Originally Posted by TJP
Originally Posted by Moparite
Glass bead/media blast always gives a nice surface look. Vapor blasting is the same process but with water instead of air.
I wouldn't go any near a glass or media blaster of any kind as the abrasive dust can get into the smallest openings/areas. Had a friend do his oil pan that was supposed to be sealed off. Even said he flushed it several times. Ate the bearings within 5 minutes of start up frown
If it had any baffles, then yes. Same as with most valve covers. But a plain pan wouldn't be a problem.
iagree But it had baffles. On a trans case ? I'll pass. Wonder if the OP knows anyone with a hotsy ?
