Unless you have a 42/904 or 46/727 style trans in your mothers van there is no gasket, and Mopar doesn't use Right Stuff. To break off the tang I use a small drift pin punch, blow it out with air if it didn't come out. You don't need the fancy tool either, don't apply a lot of pressure on the drill, allow the bit to do the work and it will be fine.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
