Anyone know of a source to replace or even rebuild a brake proportioning valve on a 2001 Ram 1500 2wd ?
OE part number is 5015419aa
Its no longer avail via Mopar and NO ONE shows one in stock .
Have a truck with a brake fluid leak and no parts to fix it
Could
this one linky be a possible solution?
https://www.ebay.com/itm/324714890647? Thanks
Ive found a few used ones. The issue is , have 2 trucks with valves leaking to some degree. Would prefer new or rebuild the ones we have.
These trucks are going to stay in service for at least a few more years. So used is last resort in fear they start to leak as well in short order. Then Im in the same boat
