My left frond disc brake drags more than the right. I have changed calipers, pads, pins, and hoses, and the left brake drags more than the right side. Is there any trick to reduce this? Thanks.
Try opening the bleeder on the LF and see if the drag goes away. If it does, hit the pedal a few times and see if it returns.
If if does, Open the bleeder on the opposite side and recheck the drag. if it is still there you have a restriction somewhere on the L side hydraulics, a sticking caliper piston, mounting pins, misalignment etc.
If it is not, then the problem is somewhere else in the hydraulics like the MC pushrod, Porp valve etc.
keep us posted
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
