Originally Posted by 340SIX
Davis battery
https://www.summitracing.com/parts/dui-5575c
Unlike some that have cut the bottom out. I cut the top off to be used as a lid. This also left the whole case intact.
I treadled the post and screwed the post in but may just bolt a cable to them and then onto the new battery inside.
I also epoxied some plastic angle {like angle iron} to hold the top in place but the factory hole down would work. I kinda go past what is needed at times.
I polished the rubber case as seen in the picture with Yellow Caps. And have 2 sets of caps in case I want the 24 to look like a 27 I kinda go past what is needed at times.
I did not use the top post cables used bolts and cables with eyelets on both sides so they did not protrude as much.
I like how you did this but have some questions:
What does the under side of the top look like before you put those posts in there? I think I would rather tap the bottom of the original posts and use double eyelet cables with bolts?
Thanks Ron
