Originally Posted by Transman
Thanks Steve !
No problem
Also note in my car picture above is the 73-76 center link. The tie rod end of the centerlink has a vertical mounting axis.
The 72 and down a-body centerlinks have a horizontal tie rod mounting axis. That might not give you as much adjustment. IIRC it will still change bumpsteer.
Top one is 73-76 -needs corresponding years idler and pitman arm
Bottom is 67-72 -needs corresponding years idler and pitman arm
