Fuel gauge works. Temp gauge will work when the wire is grounded but not when connected so that issue is more than likely the sender. Oil gauge is dead when grounded so that's either the wiring, the bulkhead connector or the gauge itself.
Karma has no menu. You get served what you deserve.
