I don't think OD engagement will cause a shake, TCC will. Iirc the internal plumbing prevents OD engagement in first and second, the OD solenoid doesn't get pressurized oil until the transmission reaches 3rd gear. This seems like it effectively keeps the transmission a 3 speed but with a really wide spread between 2nd and OD as it basically would skip 3rd altogether.
Angry white pureblood male
