I think your best choice would be the OCP ($679)intake with the MSD Hemi 6( $870 w/harness). The OCP is 4.9" tall so it should fit under stock hood. The owner is very helpful also. Remember the Hemi6 only works 32 tooth tone ring so if your engine is 09+ you need to swap out tone rings. Forget about the Prefix front distributor it was made to run CASCAR.
Depending what you have it might be a wash to go the FI route vs carb,
