Update for whoever it might help: Just got off the phone with cometic: Yes, the MLS will leak between the layers if you have a slight head warpage issue develop and/ or a head stud/bolt not holding torque when hot. Not unusual for there to be leakage between the layers when these things happen- but- the gasket doesn't "blow", it just leaks.
