Originally Posted by HotRodDave
If a hemi and wedge somehow ended up with identical flow numbers (hypothetically obviously), compression, displacement... how would you change cam specs based on the chamber and valve arrangement?
What change would you do to a cam if everything was identical but one had much shorter rod stroke ratio?
Are we betting on whether the answer to this question is ignored or deflected?
