OK, tonight. it ran great till I got it home, idled horribly and kept dying but immediately starts back up. Can't say I notice a voltage drop, but will check that out.
I went out and started it, turned on the headlights and no change. Starts immediately and runs fine when cold. This roughness is after it's warmed up at highway speeds. Almost feels like crossfiring.
Thanks.
I'm getting confused
In your original post you said:
Lately, I"ve been having what feels like a cross fire issue at idle with my 78 Magnum w/318.
Only does this at idle. If i don't hold the pedal down a tad, it'll die.
but now your saying its also "after it's warmed up at highway speeds?
The misfiring at hiqhway speeds could be due to a number of things including too much advance.
Please clarify
