I had same results as you. Measurements were all over the place. I had Molnar rods with same bolts. I just use Molnar's direction of torque to yield. Torque to 30# then clock bolt 60* if i remember right. Had great results. I think with the Hemi i will just torque the L19's to 95# spec and be done with it.
