Whats wrong with GL-5 Rated 90W???
Somebody correct me if I am understanding this wrong but the GL-5 has an extreme pressure additive package that works great to eliminate friction on high PSI contact like ring and pinion tooth contact. Problem is it also does the same thing when the the points on the inside of the brass rings try to grip the cone of the gears when shifting. You want that brass to lock onto that taper quick and stop that gear as soon as possible.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
