I need to replace the passenger power lock actuator on my Ram. Dorman lists multiple part numbers for it based on if it's single cab, crew cab etc.. yet from what I can see through the online Dodge dealer parts lists it looks like there was only one part number for all the different body styles. Mine's regular cab.
Before I order something that's wrong has anyone replaced this before and know what's the right part? And since it's the whole latch assembly that needs to be replaced is this something that's better to stick with OEM? I don't want some cheap aftermarket part that's going to break leaving the door stuck closed. Or are the aftermarket ones pretty good?
Thanks!
