Yes, will start and idle hot or warm. cold, 1 pump of the throttle and fires up and idles without being too rich once warmed up. Idles at 13.5-14:1 AFR once up to temp. I think alot has to do with the Dragon fuel i use. Good stuff. I think i used 1 blue and 1 silver spring and a large bushing from Don at FBO.
