I had a 70 340 boat motor, it had low compression cast pistons, cast crank, even had open chamber 318 small port heads from the factory and reverse rotation crank in single engine application. I still have the 4bbl intake off it, small port iron single plane with a very dramatic carb pad angle. The block would have been the only thing worth keeping butt unfortunately it was cracked.
