have a new transmission from passon installed over a year ago (still the 4 speed just beefed up) problem is when I go into 4th gear, the minute I get off the gas the pistol grip moves back into neutral. I know how to set up the hurst shifter properly with the alignment pin, I've adjusted the 4 link arms to both extremes but with no luck. My shifter is very easy to move, I rebuilt it a few years ago, maybe its too easy? What's a new shifter like? Are they pretty stiff? I do have a hydraulic clutch installed and I've tripled check to make sure I have the proper clearance from the clutch fingers to the throwout bearing when disengaged,
My car is a 71 runner for reference...
