I have a stock m2 crossmember and stock spindles.
My question is, can i switch the spindles to make it rear steer? It looks like the upper and lower ball joint holes line up with the center of the spindle so to me it looks ok, but am i missing something?
nick
I was just looking at a model A at crusin' Grand friday and it had a must.II frontend and yes the spindles were changed from side to side so the brakes were on the front, but I never did find the guy to find out what rack and pinion he used for the rear steer. and I didn't look and see if he had any issues with the strut rods.
if you reverse the spindles you have to use a rear steer rack or you will be steering backwards Ron...
