I have some Firm Feel arms on my 67 coronet.
Non Adjustable. They aren't designed to add huge amounts of caster and neg camber but even with rear of the car higher than the front I got 2.5* caster and -.5* camber. I imagine I'm losing a few degrees of caster from the stance of the car. Might drop the rear by moving the front spring into the upper bolt hole...
