Back to building another engine for the Copper Dart. Picture explanation is of the replacement piston compression rings. The smaller ring is the top ring and the larger is the second. My concern was the stock piston has the same ring groove depth for both upper and second rings. The stock rings were both the same size as the replacement second ring. Seems kinda small to me. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
