I put a 8 3/4 in my 67 dart and added after market disc kit. Could not get brakes bled. Tried several time pedal went to the floor.
Replaced master, bench bled, bled and pedal still goes to flood. Manually and power bled and same issue.
Added a proportioning valve to back, bled and same issue.
just added a Tee to front bake line and removed distribution block. Bled and same issue.
Replaced both rear calipers, bled and same problem.
Went through a least a gallon of brake fluid already.
I know there is air somewhere but can't find it.
Any ideas????
