Originally Posted by edison1970
When I depress the pedal when it's running, the pedal goes down 3/4 of the way before the brakes start to work.
If the pedal drops with the engine running, vacuum isn't your problem....the booster is working.
Have you adjusted the rear shoes for a slight drag when turning the wheel? Loose drum brakes will eat up a lot of pedal travel.
The INTERNET, the MISinformation superhighway
