I'm new to EFI but I have a plan, I just need a bit of schooling to get me started. I have a manifold & I'll be using the Edlebrock Pro Fuel rails with Bosche 1000cc injectors. If I go with the Holley Terminator X kit, what other parts an I going to need to add to make this system work. I'll most likely be using a Joe Blow efi injector hat but not use the in hat injection system it can be bought with & the Magnafuel efi fuelpump. Thanx for any advice available. .
