Did the 67 Coronet R/T with the standard 440 engine come from the factory with the hemi power brake booster if it was ordered with
power drum brakes ?? I was told that this particular combination had the same booster as the hemi. Supposed to be larger mounting hardware ??? Hopefully someone can educate me on this. Thanks in advance.
Bennoel
