e street, rpm or ported 452
#2914992
04/25/21 11:40 PM
04/25/21 11:40 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Heres my set up ....which heads would you run?
3400 65 b body 383. Stock bottom end. 1970 short block ultra low mileage. Zero ridge factory cross hatch still in place. Crower .500 / 290 advertised mech flat tapped lifter Tunnel ram with 450 holleys Hooker comp headers. 3inch exhaust. Summit flow master knock offs Crane iron rockers Mallory unilite dist. 143 tooth flywheel. 23 spline 833 with liberty pro shift gears Dana 60. 4.10 power lock. Mini tubbed. 325/50-15 tires
Currently have ported 452's in the shop. 2.14 / 1.81 valves. Have a local guy with a set of e street and a set of rpm eddy heads. Both 75 cc chambers. Prices are reasonable. Compression ratio figured in my head: 452s have been surfaced. Steel shim head gasket 452 heads 9:1 Eddy heads 9.75:1
With those compression numbers i think my cam is too big but then again i have seen worse run well. Crower recommended 9.2:1 Not moving away from solid lifters.....and this is the short block I have ready so I'm sticking with that.
Thinking the 75 cc chambers will help..... I could mill my 452s down.
Which heads would you choose? Rpm ports too big for a 383?
Im unlikely to go smaller in camshaft. In fact i have two larger ones on the shelf. Next one up is an stx19 racer brown mech flat tappet.
Which heads would you use or please feel free to correct my combo.
Its a street/strip car.....i don't plan to rack up miles and miles cruising.
I used to care but....... things have changed
Entire Thread
NTOLERANCE
04/26/21 03:40 AM
Re: e street, rpm or ported 452
dOrk !
04/26/21 04:25 AM
dOrk !
04/26/21 04:27 AM
Cab_Burge
04/26/21 06:24 AM
Moparteacher
04/26/21 04:34 PM
clovis
04/26/21 09:20 PM
carnut68
04/26/21 09:31 PM
NTOLERANCE
04/28/21 01:11 AM
NTOLERANCE
04/29/21 02:04 AM
Cab_Burge
04/29/21 04:54 AM
NTOLERANCE
04/29/21 05:11 AM
viperblue72
04/29/21 04:29 PM
RTSrunner
05/04/21 04:56 AM
krautrock
05/04/21 01:41 PM
