The Wallace Calculators have an "ideal" calculation which you can base on any part of your time slip. I find it useful to see if there is any portion of the run that could be improved. If you plug in your mph109.33 your ET should be 6.22 and your 60 ft should be 1.37. If you use your 6.32 ET, then your 60 ft is spot on and you are fast, as it says you should go 107.55. I would lean toward the idea that you may have some 60ft left to be found.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
