Originally Posted by Andrewh
I think you might have the wrong headlight switch.
If it started when you did that, I would look their first.
if you still have the old one, I would reinstall and see if both issues persist, depending on what was wrong with the old one.
The headlight switch was never changed....
sorry read that wrong. Turnsignal switch then. or it was wired wrong.
Anything is possible, it was the only one listed for a 67 on his site. Wiring was just plug and play with the harness. I’ll look into that as well, thanks.
