well it started right up after about 5-7 seconds of cranking.... little lifter clatter for 10-15 seconds then quiet.. little smoke for 30 seconds then all clear...dummy me put an oil gauge sender on it and it has an idiot light only...doh.. also reman w pump started to seep a bit so its prob junk even though its new rebuilt... no big leaks.... yet... moves under its own power... brakes need a good pedal bleed..then glass and seats and she is mostly done.. used the blue racer 280-290 443/465 cam... very light lope is all... temp gauge inop... dash not assembled yet because of those kind of things...so tomorrow
we will see if it drips anything [cardboard under it] ... sure nice after 35 years...
