Originally Posted by Cab_Burge
Pull the squirter part off and if it is has a square check valve shoot some carb cleaner on top of it and let it sit a little while, do that again and try and use a small diameter wire to move it around to make it loosen so it will squirt scope
If it has a round check valve take the carb off first and go from there wrench shruggy
It's a stock OE 6 barrel carb. No modifications.
