Cost will be anywhere from $5k-$9k for that, depending on the shop costs, what parts you buy, where you buy them, and if you do any of the assembly work yourself. Starting with only a block you can figure a higher number because all the little parts really add up. Might be better off just dropping in a BluePrint stroker motor with 50k warranty, unless you are looking forward to the experience/process.
