Re: Buying a Hemi...who builds the best bargin?
[Re: mickm]
#290120
04/20/09 09:04 PM
04/20/09 09:04 PM
Posts: 1,411 Tallmadge, Ohio
Paul_B
Tallmadge, Ohio
I am gathering parts for my Hemi as well. Other than the K Member, what else would you need to put it into a non factory Hemi car?
that depends on how correct you want it to be, or if you are building a car that you aren't concerned about it appearing stock.
after the k member and mounts, it will be sitting in the engine compartment just fine. these are the things i can think of offhand...
- positive battery cable is different - throttle linkage and cable - there are pulley and bracket differences - harmonic balancer - air cleaner - 18 spline if it's a 4 speed
i know there are more things, but it escapes me at the moment.
once again, just depends on what you will be building. big block positive battery cable works just fine, depends if you want the hemi one or not, things like that.
When I did my BB to Hemi swap I used Schumacher conversion mounts, bigblock pulleys and balancer. Don't forget about the 8 bolt flex plate/flywheel bolt pattern on the hemi.
