Originally Posted by dragon slayer
The only difference between B and E is the petal center link length. Not sure many are reproducing these anymore. They are using the generic one I think with the smaller booster bolt pattern. If you find one make sure it has the pattern of the booster you are using.
I use to repro both brackets years ago, not anymore....IIRC DrDiff also offers both sized brackets
MikeG
