I ordered a set of Holleys new 1973 to 93 D 150 5.7 Hemi conversion mounts and they do not Fit for [censored]. This is a rolling frame so I have plenty of room to move things around and the only way I could get it on the mounts was to leave the isolators loose on the frame and worm it around to go get the studs in the engine side then let it down. Very frustrating to say the least and had the front clip been on it would have been way worse ! Also I am using 2018 Ram 5.7 and driver side exhaust manifold hits the frame{will get notched } and brake proportioning valve is right there also.
