One of the magazines did a big bore short stroke vice versa dyno comparison some years ago. Same heads, cam and induction.
I don't recall the difference being more than a few HP.
As far as which one might be faster, I suspect if there is any difference between 2 engines that make the sameish power, it will be the engine that can accelerate itself the quickest.
Kevin
