I've never had a ring seal problem even when I use to dip the complete piston in oil and never wipe the cylinder walls down to remove the excessive oil shruggy
I have also tried installing the rings and piston dry using the old Total Seal recommendation on their zero gap rings back in the mid 1970, only once though realcrazy shruggy
