I'd hazzard a guess that that was not an engineered building. Just out of curiosity, where's the beam that's supposed to be supporting that I-beam ??
I'm not the only one who noticed this! If you look at the end of the "I" beam it look like somebody welded a plate on the inside. This is not the way to weld I beams together. Back yard builders probably. Hopefully either the vehicle or homeowners insurance will cover it. And have somebody skilled rebuild the roof.
