I just had a set of edelbrock magnum heads checked out and the best seats were .002 out of concentric, the worst was .007 out, and all 8 intake guides were tight, so tight you had to push the valve down with force. Exhaust guides were fine. The valves also all needed faced. The worst set of heads I have ever seen by far for new.
