Originally Posted by LaRoy Engines
I think I would rather multiply the lobe lift by the rocker arm ratio. Some Magnum cams are listing their lift with a 1.6 rocker ratio..
That’s not what the OP asked.
Obviously the best method to determine valve lift is to measure it. And forget what’s in between the camshaft and valves.
